f.pehlivan
Good day guys. I am getting a double reinforcement error on the tiles in the project I have uploaded, can you help me, I could not solve the problem what I did. Thanks in advance.
Hello, The reason for the double reinforcement warning in your project is that the slab analysis is not correct. The boundaries of the D38 slab are formed incorrectly. Connect the slab edge at the nodal point of the K58-K98 beams and reconstruct the slab. Also, some beams in the basement have been given +70 cm elevation. However, the columns to which the beams are attached are not given an upper level. (S16-23-25) Vertical continuity should be ensured by raising the relevant columns on an upper floor."f.pehlivan":1orkz42c" said:Good afternoon guys. I am getting a double reinforcement error on the slabs in the attached project, I could not solve the problem what I did, can you help me. Thank you in advance.
