It will be enough to move the beam carrying the landing on the 1st basement floor. The proposal demo project is attached. Ünver ÖZCAN"erdigoksu":3680b8jx" said:I would appreciate if you can help me how to create the floor at +1.09 level.
In the architectural project, the entrance is made at 0.00 level and there is a landing in front of the elevator at +1.09 level. I could not enter the landing floor at +1.09 level, thank you for your help and attention. I saw your suggestion, thanks for the arc area in the beam connections. Also, I could not connect the columns to each other due to architectural reasons (duplex staircase) on 3 floors."NYILMAZ":28ygkhmv" said:Check the notes in the attached project. Some questions have answers as well as some other questions.
I'm writing from a tablet right now. But my advice is if you add the architectural project, more logical solutions can be offered. I think that the stair layout on the upper floor should be taken to a different place (the architect can do a different work). I could not understand the condition of the columns in the main stairwell."erdigoksu":6dx9gc3z" said:I was able to get the project like this lastYou do not have permission to view link Log in or register now.I still can't define the landing at +1.09 level, really thanks for your help
--No deflection error either,"unalmh":2ckg7lme" said:1=) FRIENDS WHAT CAN I DO ON COLUMNS THAT DO NOT PROVIDE CUT SECURITY . "unalmh":2ckg7lme"]2=) THERE ARE PLACES WITH 150 CM EXTENSIONS, THERE ARE 50 CM FREETS IN THE LAST STAGE, THE CONSOLE LENGTH IS 2 M HOW CAN WE SOLVE IT ?
--Do not change the size of the S6 column, --Make the narrow side of the other columns 30 cm, --Semi-rigid Make a solution, --You can remove the wall loads in the attic and reduce the live loads, --In the attic, lift the K22 beam and start the rib beginning from the H axis, --Make a solution with the ladder, --If you want to save, decrease the raft thickness by 5-10 cm."unalmh":2ckg7lme" said:I ADDED THE PROJECT, IT PROVIDES WHEN S6 COLUMN SIZE IS 40/40 BUT HOW CAN WE BUILD IT IF WE DO 30/30?
You can even make the beam width less (10-15 cm). No need to put reinforcement like beams. Bottom top 1Q8 The purpose is not to leave the hollow filling material empty."unalmh":2mw8vz16" said:SO WHAT DO YOU SAY ABOUT MY WRITING ABOUT THE FACE BEAM IS I DOING WRONG?
