facade lovers
memorandum
Hi, I don't know how I succeeded, but he always makes his fans inside the front, not outside. what is the trick. good work
Hello there; Perspective on the screen; Rotate the building so that you can see the exterior view of the facade columns that you will form the purlins. Then, as you know when modeling purlin, 2 green arrows appear on the elements you selected, make sure these arrows are located on the outer face of the column. Good work.
