External dimensioning error in formwork plan and other drawings
hatipoğlu
THE EXTERNAL MEASUREMENT IS NOT VISIBLE ON THE MOLD PLAN AND OTHER DRAWINGS WHAT SHOULD I DO. CAN YOU HELP ME ? NO OUTER MEASUREMENT AS I SHOW IN THE ATTACHED PICTURE
Re: EXTERNAL MEASUREMENT ERROR IN MOLD PLAN AND OTHER DRAWINGS
"hatipoğlu":1guj0fm0" said:
EXTERNAL MEASUREMENT DOESN'T LOOK IN THE MOLD PLAN AND OTHER DRAWINGS. NONE
Hello, Run "Calculate Contour" command from the Right-click menu in the Floor plan window. Get the mold plan again. If the problem is not resolved, attach the project file. Good work
Re: External dimensioning error in mold plan and other drawings thank you very much, I applied what you said and it was solved.
