Leader, Light burst in the render because you set the value of the wooden texture you defined for the texture to 250 This value should be 100. (1) Also, the texture you choose for the texture is actually the bump texture of ahs02 texture. You should use ahs02 for texture, ahs03 (black and white one) for embossing.(2) When you define 2 You will get a result like in Render settings. In the render settings, you have defined the exposure value as 2. This value should be 1.1. The exposure value affects the brightness of the entire render. When you want to increase this value, you should make small increments such as 1.1 , 1.2, 1.3. Finally, you are rendering in the daytime, the shadow size is large. You can get the noon sun effect when you make the angle of the sun with the vertical in the physical sky tab in the render settings to prevent it from happening. niz...
