Excessive reinforcement problem in joist slab
Re: EXCESSIVE REINFORCEMENT PROBLEM IN BEAM FLOOR Hello My suggestion --Fix the errors in geometry control, --Remove wall loads over beams, --Spans are large, beam height is low, reinforcement is too high. If you increase the beam heights by 10 cm, the reinforcement will reach reasonable levels. --Delete and recreate the tiles that form corners with the curtain, take it easy Ünver ÖZCAN
Hi -- If you post what hasn't been fixed and what you expect, I'll take a look. --Add the corrected project. Unver ÖZCAN
