Greetings to all, While there are no errors in the reports in the attached project, there are too many deformations in the S02 and S10 columns in the Ux and Uy directions in the analysis and display options. The same situation exists in the stud beam that I have thrown for the building. Will this cause any problems for the structure?
[/ quote] Hello, I have examined your project. There is no abnormality in the structural deformations. If you mean the red color in the color scale, the colors you see correspond to the values specified in the color scale on the left of the screen. The color tones in this scale are always the same. It is not appropriate to evaluate by looking at the tone of the colors, at the same time, you need to consider the value that the color corresponds to on the scale. Marking ux means only showing the displacements in the ux direction. In the project you added, the displacement appears as 0.8553 mm. There is a subfloor definition. It is given as a warning in geometry control. You can delete faulty tiles as described in the link below.
Good work
