Excess element count control
engineer_yildiz
Dear Sir/Madam, 2 separate beams at the same level and dimensions are connected between the two columns (1 of which connects 2 columns, the other cantilever beam at this beam projection). We cannot see these beams, which are formed for such a reason, under GEOMETRY CONTROL. Question1: Is there a method (made by the program) by which we can easily detect this? Thank you and have nice work
Hello, Normally the program does not allow such data entry. You cannot draw a beam on a beam. However, if a little angle is given between the two beams, it may be drawn. In this case, the program warns the user on geometric control.
