Example Ladder Types
M. Berat Denli
We will collect the sample ladder stm files we made under this title. You need to put the ladder stm files in the ladder library. For this, go to the directory where the program is installed and copy the downloaded file into the "C:\Program Files\ideCAD\ideCAD Static 8.61\stair" stair file. Then start the program. From the Ribbon menu, choose the ladder type you have transferred to the stair file from Ladder -> Ladder Settings -> Stair types. Two Arm Ladder with Intermediate Landing Two Arm Ladder
Two-Armed Ladder-2 Two-Armed Ladder-2.PNG Two-Armed Ladder-2.PNG (34.12 KiB) viewed 11 times
I think your drawing of two-armed ladder-2 is not correct. yes, it is the same as the axis of calculation and supporting conditions, but the one drawn with the desired staircase is not the same. Drawings need to be corrected again. The first 7 steps of the desired ladder are straight but at an angle that you have drawn. Also, it was entered as a landing, not a 9th step.
