Hello, I just started work and I have been working for 1 week in order to improve myself in IdeCAD. They gave me an architectural project that has already been statically designed and approved to work on. I drew the project by following the existing static project in order to draw a path for myself. Mostly I found the cause of the errors and completed it, but I am having serious problems on two different issues. 1st problem I get the error Beam exceeds Nmax limit on many beams in basement. The only difference I noticed with the current project is the reinforcement lengths noticed in the beam openings, but I couldn't find how to make the change here, or what solution can you suggest? The second problem is the Axial Capacity Insufficient error I encountered in the S58 column in the basement. Here I could not discover the difference with the current project. I would be very happy if you could help me with the problems. Also, I noticed that the concrete cover parameters are below the TS500 standards in the current project, what kind of a problem is this? Because, as I just said, the project has been approved by the municipality. Thank you in advance for your support.
Log in or register now.
