Hello In your project, certain line is marked in the Behavior Spectrum Function dialog, but no curve is defined."cem":ddx6edsb" said:hello. When I want to analyze my project with ide 6.54 v., the program analyzes for a while and then idecad encountered a problem, it needs to be closed, and the program closes. Can you help in this regard, thanks in advance.. the project is attached
Findings and suggestions about the project; If the soil is not group D in your project, since earthquake loads are used in the soil stress control Analysis Settings/Foundation-Soil tab [ b] When using Earthquake Loads, increase soil stress option can be selected[/b] Analysis Settings/Foundation-Soil tab Use multi-conjugate winkler spring method on matte foundations line can be checked. The concrete cover remained 1.5 cm in the raft flooring parameters."cem":38czb6jt" said:Levent, I want to ask one more thing. There are 6 floors in total in this project I made with ide. When I build a mat foundation, it does not save the bearing capacity at 70 cm high. I tried it in another program. It saves 60 cm easily. I wonder I'm making a mistake somewhere. Thanks in advance for your attention..
