CAN YOU HELP? Since a curtain is attached to all columns in the y direction in the project, column buckling and accordingly Nk values are calculated as zero. 1-You may ignore the warning. 2- You can mark the Column Free height as "Defined" in the Column Properties/Static Reinforced Concrete tab and enter 3 meters and perform the analysis. You won't get it. Good work
