Error saving report
omeragar04
Good work guys. How can I fix the errors that occur in me while receiving the report? 1. How can I delete the text 'Report # 19021' in the upper right corner as seen in the picture. 2. No file information found for font when saving reports: Verdana is in bold. When I say ok, it says 'iderpt.exe has stopped working and closes the program. I would be glad if you help. Thanks in advance
Hello, 1-The barcode number in the upper right corner of the report is given automatically in version 7, it cannot be removed. (On request, barcode numbers are not given in General analysis reports as of Ver 8 version.) 2- You probably get this message while saving the report as pdf. Change the font of Page Title, Subject Title, Subject subtitle, Table Title and table Information under the Font menu. For example, make Times New Roman. Try again. If the problem is not resolved
version 8 of the team viewer program Install the version and contact us. tel: 0224-220 67 17 Good work
Levent Bey has no problem changing the font and saving the pdf file. What I wanted to know was to know if there is a permanent solution without changing the font each time. As far as I understand from your answer, there is no such solution. Thank you for your answer.
