Error Receiving Report
damlaozgur
I am getting an error like this when receiving a report. According to the information in the forum, I changed the language and translated it to Turkish again, but it does not work. I am using windows 10. can you help me ?
"damlaozgur":xpuv2wz2" said:
I get such an error when receiving a report. According to the information in the forum, I changed the language and translated it to Turkish again, but it doesn't work. I'm using Windows 10. Can you help?
You can get a report in your project. The problem on your computer is to the reports in the program installation folder. To solve the problem, follow the steps below. -Disable any antivirus software. -Close the program. -Uninstall the ideCAD Static 10 program from the Add/Remove Programs section. -C:\Program Files\ideCAD\ideCAD Static 10 folder -Delete the C:\Programdadata\ideCAD10 folder. (If you can't see the ProgramData folder, it may be in a hidden location. You can make it visible by checking the "Show hidden files and folders" option in the "Folder and Search options" section.) -Install the program again. -Left of the keyboard Press and hold the Ctrl and Shift keys at the same time on the desktop. Run it by double-clicking the path. Do not release the Ctrl and Shift keys until the "Registry entry and settings have been cleared" warning appears. (The warning may also remain in the background) -Click OK on the warning that appears. -When the program opens, try to load your project, analyze and get a report.
Thank you very much for your interest and interest, I solved it by following the steps you said. Good work, thanks again
