ERROR OCCURING WHEN OPENING OLD PROJECT
dester
I wanted to open the projects I drew in version 5 and check some accounts, but when I switch between floors, it gives an error that the memory was not read. in different projects. I would appreciate if you inform me about the problem. The project is attached.
I looked at your project, there is no problem. For some video cards, it may be necessary to turn off the 3D drawing mode in the General settings of the program. Can you turn it off and try again? Good work
Hello dear dester, I downloaded your project, I tried to open it in the latest version, as you said, the program closes as soon as you open it. As a solution, I saved as a solution, I checked the geometry in your project without focusing on three dimensions.. It gave 226 errors in the geometry control.. I think the geometry errors in your project because of the shutdown.. Check the geometry in your project, debug the errors..
I couldn't open the project I made in a 5 give me too. can you help me. Since I could not open the file, I sent it in a compressed state.
Hakan, I have 6.0051 but it comes to the attached place and closes. I turned off the 3D drawing mode from the general settings, but I could not turn it on again.
As we talked on the phone, Serdar Ambalaj_tam_ekran.cde was opened. This way you can continue your work. I also suggest you to try updating the driver of the asus x1700 video card in the notebook from asus.com. Good work
I have 6.0051 demo, I open these projects and when I want to examine them with the interactive camera option through the perspective window, they become wireframes. Is there a setting for this? I cannot examine it in a solid state. When I want to visit the building with the interactive camera, it immediately becomes a wire frame, thanks
