Error in stair detail drawing
NYILMAZ
There is an error in the section of the staircase detail drawing. The reinforcements that should be in the section are drawn somewhere away from the section. The step dimensions are also far apart. (It can also be seen in the attached funny picture.) Moreover, in order to make an arrangement, it is necessary to make a lot of pieces of objects one after the other. I think it should be reviewed. The drawing is very messy.
This problem has occurred before with another file. This time, I wanted to let you know. The strange thing is that there is no such problem on the ground floor that I created with floor copy. But other floors have this problem. Good luck with...
"NYILMAZ":vi16do7k" said:
This problem has occurred in a file before. I wanted to report this time when I came across it. The strange thing is that there is no such problem on the ground floor that I created with floor copy. But there is this problem on other floors. Take it easy. ...
We have added the situation to our notes. When the relevant staircase is copied to the ground floor and the drawing is received, the stair reinforcements are drawn inside the staircase. You can use this method for the solution now.
