Error in ideCAD dynamic analysis report
eissenhover
hello everyone. While I was working on a project in idecad8, I noticed an error regarding the building mass while examining the post-analysis reports. When I look at the quantities to see if I am wrong, for example, I see a column of 100x100 and a height of 3 meters (an element with a concrete volume of 3 m3) when I look at the analysis reports, the total mass of the building is 0.382 tons in the "VIBRATING MODE SUFFICIENCY NUMBER CONTROL" section. If we say that 1 m3 of concrete is approximately 2.4 tons, our column should be approximately 7.2 tons, but it means 0.382 tons. I do not understand anything about this, I would appreciate it if you explain
Re: idecad error! Hello Since the lower joint of the column is fixed, its free mass is calculated as its upper half. The effective modal mass is divided by 9.81 and the report is printed. This situation will be fixed with the update, it is related to reporting and there is no situation that will affect the analysis results.
Re: idecad error!
"eissenhover":328tf3ua" said:
hi everyone. While I was working on a project in idecad8, while examining the post-analysis reports, I noticed an error about the building mass. When I look at the analysis reports, the total mass of the building is 0.382 tons in the "VIBRATING MODE SUFFICIENCY NUMBER CONTROL" section. It says 0.382 tons when it should be 2 tons. I don't understand anything about this. I would appreciate it if you could explain
It is an error related to reporting. It is printed by dividing the mass into 9.81 in the report. Modal analysis and response does not affect the spectrum results. Reporting error will be fixed in the update.
