"celikus":2mno18ph" said:
Friends, I solved the project with continuous foundation, no problems arise, but when I want to solve with raft foundation, the analysis does not end. The slab loads are calculated on the elements and it stays on "Calculating the ground floor". I couldn't find the problem, can you help?
Hello, When the raft foundation is defined in the project, the analysis actually continues. The reason why the analysis took a long time was the interactive solution of circular columns and superstructure. The number of points of the circular columns in the project was 40. In the attached project, the number of points of the circular column was given 15 and the columns were placed again and the mat flooring was defined. Analysis 128 min. completed in such a time. Since the columns are redefined, I recommend checking their eccentricity for the project. Good work
