Hello everyone, I edited the dimensions of a column in a project I was working on with the 'change column dimensions' command, but the column dimensions did not change on the ground floor and when I came to that floor and checked it, I realized that I could not select the column on the ground floor. It always keeps either the beam or the floor next to it, but it does not see the column, analysis errors It also gives an insufficient reinforcement error in the beams connected to that column, I think it is probably related to this error, but I can't find where I made a mistake, I would appreciate it if you could help.
Log in or register now.
