Equation 3.14 on curtains
muhendiz381
good day mr. In my projects, Ag/Ap>0.002 part in equation 3.14 is shown in red and as a cross. There is no requirement in the regulation regarding this issue. it says that if you meet the conditions in the regulation equation 3.14, you can reduce the wall thickness up to 15 cm. although this rate is not provided in another project, there is no control. This issue was not even mentioned in the reports. I don't understand why idecad gives this control to reports or not.
Hello. Curtain ratio control is the control that allows the wall thickness to be reduced in tunnel formwork projects. Except for tunnel formwork projects, the "Screen Ratio Control" report should be removed from the optional reports and a report should be obtained.
"YasinTezel":1qzmv3hr" said:
Hello Curtain ratio control is the control that allows reducing the wall thickness in tunnel formwork projects. Except for tunnel formwork projects, the "Screen ratio control" report should be removed from the optional reports.
When I click on the general earthquake report, Mr. Yasin and it appears when I get all the reports. I was surprised because the system did not have a tunnel pattern, so I encountered this situation in my last 3 projects. This situation arose when I made an old project made with ide7 with the latest version.
