Eps insulated molded reinforced concrete load bearing wall static
cankara
hi, can the Eps insulated molded reinforced concrete load-bearing wall (EPS YKDBT) static project be drawn and analyzed in the idecad static program?
Re: Eps insulated molded-reinforced concrete load-bearing wall stat Hello, The design and drawing of reinforced load-bearing walls as you mentioned in the program are not done, but they can be analyzed. If the load-bearing walls you mentioned are to be included in the building analysis model and are continuous throughout all floors, a material with the properties of the reinforced wall can be defined and this material can be modeled and analyzed with the curtain command by assigning it to the curtain properties. The cross-section effects after the analysis should be examined and all necessary verifications should be made by the user (not automatic). Good work
