ENG. PROJECT ON MONDAY. I HAVE TO GIVE IT TO HIS ROOM..
kltinsaat
I CAN'T GET R COEFFICIENT 7. THE TIME I RECEIVE IT GIVES AN ERROR THAT R COEFFICIENT IS 7 AND THE RATIO OF CURTAIN CUTTING FORCES AND BASE TOTAL CUTTING FORCES IS HIGHER THAN 0.75. I ADDED THE PROJECT, I HAVE TO ENTER THE ROOM ON MONDAY.. LOTS OF PRAYER TO THOSE WHO WILL HELP. THIS OPPORTUNITY WILL NOT MISS :)
Hello there; You have entered the basement curtain in your project, but you have not introduced to the program that these panel elements are the basement curtains. To do this, you must select all panels and select sub-basement curtain under the heading properties/static/reinforced concrete. so you can take R=8 and solve it. Good work.
"2m project":8y33qcfd" said:
Hello; You have entered a basement in your project, but you have not declared that these panel elements are infill curtains to the program. To do this, select all panels and select under the heading subflooring/static/reinforced concrete You must mark the pitch option, so you can get R=8 and solve it. Good work.
I SEND WHAT YOU WANT TO YOUR ADDRESS :)
