Endpoint edit
"mertkaanari":2qcga5mg" said:
hello, the edit endpoint command in idecad 7 is not available in idecad 8. is it removed or I can't find it
Hello, the edit endpoint command is not removed, it's only improved in 8. The shape is as follows: 1) First select the element, 2) Move the mouse to the tip of the element you want to edit and click on it.You can now move the tip wherever you want. Also, unlike 7, in 8, you can mark more than one element in the intersection, and at the same time you can select all the ends of them one by one. you can move at once and the command also works in 3D. Good work
