emergency staircase drawing
tedarmi
friends, I uploaded the static project below, I also took the photo of the staircase that needs to be drawn, can you help me, no matter how hard I tried, the stairs are coming out of nowhere
Re: EMERGENCY LADDER DRAWING By using the closest type in our library, the ladder in your project can be easily placed with the stair deformation command only where there is a curved wall. In addition, as a second method, it can be modeled by drawing a stair contour and exit line on the plan with the route command and creating a user-defined stair. I created your ladder using both methods on your project. You can download and use it directly from the link below. I also moved the route objects that I created the ladder out of the project for your review. It will be helpful if you try to create your own using these. A little warning: In the architectural plan picture you shared, it says 15.5 berth * 18 on the stairs. When it was created in this way, the floor height was taken as 2.80 in the architectural project. You entered 3 m in the project you sent. I set the ladder according to 3. Good work
