First of all, I wish you a good work guys, my question is, there is a silo the top of the silo is made of steel accordingly a foundation with a raft system ] will be done silo(full state)+ steel system =400ton weight I gave 6.75ton G(dead) load to m^2 because it is in an area of 62.75m^2[ /color]... when I give a live load, it takes 30% of the live load because for the silos (from the regulation, earthquake regulation and ts6989) I got the R coefficient of 3, I got the Z2 floor Z3, I got a ground safety stress of around 15t/m^2 in negative stress control in raft foundations (50% I didn't get the increase) I did, I'm waiting for your help if I have a mistake in the modeling in order to stay on the safe side in the analysis? 1) I'm going to build a raft with a beam or a beam at a height of 100 cm, then around 5 tons of iron 90 m^3 around c25/30 concrete comes out ------------------------ ---------------------------------------------------------------- ---- 2) Or make a raft without beams and 120 cm high, then around 9 tons of iron and 110m^3 c25/30 come out --------------------- --------------------------------------------- I prefer 2nd I am using it from side to side because there is a functioning in the factory and I have to deliver it within 2 days. Which system would you use... I am waiting for your criticisms and opinions. Thank you.
