EMERGENCY ANALYSIS ERROR
Our NUMBER SITE MANAGER EK been ROADS MAKE'm PROJECT FIRST FORWARD ANALYSIS MADE BUT OWNER SETTING GROUND SAFETY AFTER CHANGE THE VALUE ANALYSIS WANT TO MAKE I SYSTEM NOT UNRAVELED MODAL ANALYSIS CAN NOT FAULT GIVES when EMERGENCY AS ASSISTANT OLURSANIZ SEVİNİRİM PROJECT in SAYGILAR.EK FIRST ANALYSIS MADE OF STATE AFTER Birdaha ANALYSIS KEY PRINTING ERRORS GIVES
Hello there; When you open spaces in basement curtains, you should model the curtains as shells, I think your problem was caused by that. Also, there were some problems in some of your beam-beam intersections (K127-K122) (K227-K222), and the lowest vertical reinforcement diameter should be Ø12 for carrier walls. I am adding the model I corrected and analyzed. (version 6.2004) take it easy... best regards.
Hello In addition; The problem has nothing to do with the reinforcement setting and the change of ground parameters. In modal analysis, the error message occurs because the frame system is not created correctly. Make sure to check the geometry in your project, the program will show you the errors.
