Emergency aid !!!
o_berdibek
1-Hello, in my attached project, the amount of reinforcement for the 3rd floor column is higher than the other floors, I could not understand why, am I doing something wrong in the program, please help
Can I move the A, B and C blocks that I solved on different pages as 2-dilated to one page? Thanks
Re: EMERGENCY HELP !!!
"o_berdibek":31jlumm4" said:
1-Hi, in my attached project, the amount of reinforcement for the 3rd floor column is higher than the other floors, I couldn't understand why, am I doing something wrong in the program, please help Please
Hello, When the column design effects and column capacity diagrams are examined in your project, there is no problem in the reinforcement. The determinations for data entry are as follows; *The borders of the beamless raft slab are incorrect. The slab edge is not defined on the left. (The slab edge is also drawn under the continuous foundations. ) *Continuous foundations are defined on the floor where there are no columns. Columns should also be defined and leveled in the basement. Also, TK01 continuous foundation is not connected to the panel object at the node point. (You can connect the continuous foundation to the S07 column) *Slab edge is drawn under the K7 beam on the ground floor. )
2-dilated A,B and C blocks that I solved on different pages can be transferred to a single page Can I post it? Thanks
There is no way to merge projects with a single command. However, you can convert each solid (or drawing window) into a block file with the Copy to File command under the Project menu and transfer it to another project file with the Paste from File command. Good work
