hello first of all. According to the sample elevator shaft project on your site, I first opened a slab gap in my own project, after passing with the slab edge, I defined a new slab. I gave the curtain and the new slab at -150 elevation. When I analyzed it, it gives an insufficient error of basic section, which is normally 60 cm. I tried the foundation up to 100 cm. . It saved a 100 cm section, but this time it gave a negative ground safety error. I couldn't figure out exactly what the problem was. Also, some designers don't do this. They show the well in the drawing. It's basically opening a gap, giving jeans. They don't do anything, or rather they don't see it as necessary. How accurate is this? Since my project is big, I could not upload it directly from the link below. Thank you in advance for your attention.
Log in or register now.
