Elevator Room Errors
"huseyinakkus56":1xqdrvkr" said:
Hi.. I solved the problems if I didn't add the elevator room in the project in the link, but when I add the elevator room, there are errors. Can you help?
Hello, if you mean "errors occur", if the problem of cross-section deficiencies in the beams on the ceiling floor of the elevator room (maximum deviation, torsion, shear safety, balanced reinforcement), K60- Define beams K61, K68-K69 with the same width, or analyze by ticking the line "Ignore beam torsional stiffness in conformity torsion" in the Beam Parameters dialog.
"huseyinakkus56":dysa63eg" said:
https://we.tl/t-rLMFZQ0w6i I have the same problem in my other project in the link. If I do not add an elevator room, there is no problem. When I add it, it breaks the project for some reason
elements are not defined.There is no change in the analysis results in case of deletion of the elevator floor with the current state of the project.
"Levent Özpak":3f6mn5ef" said:
"huseyinakkus56":3f6mn5ef" said:
Hi.. I solved the problems if I did not add the elevator room in the project in the link, but when I add the elevator room, errors appear. Can you help me?
Hello, you mean "errors occur", the section formed in the beams on the elevator room ceiling floor Define beams K60-K61, K68-K69 with the same width. Or analyze by ticking the line "Ignore beam torsional stiffness in conformity torsion" in the Beam Parameters dialog.
When K60-K61 made the K68-K69 beams the same width, all the errors were fixed. Thank you
