If you noticed, I wrote the word analysis in capital letters in the title. My goal in this is how the analysis of the pit drawings applied or drawn on-site, rather than how the elevator pit will be designed in terms of manufacturing. Or maybe it's how it isn't or even whether it is. Since this issue has come to the fore in different ways, I would like to bring it to the agenda again in this way. I would like to approach the event primarily from an engineering point of view rather than traditions, practices and programs. Then, respectively, programmatic, application, etc. We can continue as Now I will show two types of foundations: 1- The foundation is defined as flat, the pit has not been dug, the analysis was made in this way. Stress values are shown on the picture. In this case, as we observed in the forum, IdeYAPI; If it is modeled in this way, it recommends that the mat slab thickness be made in the main raft thickness, including the bottom of the pit. 2- A pit has been opened on the foundation, but the carrier elements (column or curtain) around the elevator press the edge of the pit, that is, the main raft. In other words; It is modeled as the side column (or curtain) pressing on the raft in the adjacent structure. The model and stress pictures related to this situation are as follows. A plaque will be drawn under the second model, again constructively, and its surroundings will be filled with concrete. Considering these two cases, the second model creates more unfavorable conditions in terms of both stress values and additional reinforcements, isn't it? (the strain value is seen to be 17 t/m² in one and 19 t/m² in the other) Isn't it a closer model? From this point of view, which of these two analysis choices is recommended. How does IdeYAPI look at this situation? In summary, I would like to talk about my own method: After making the second model and worshiping the analysis and additional reinforcements according to this unsuitable situation, I constructively draw ONLY the SECTION (ie the pit) THAT WILL SUITABLE FOR THE LIFT WORKER WORK. The drawing I made is as follows. Here, in terms of feeding the main foundation, the inclined section resulting from the excavation should either be filled very well or it should be filled with concrete as in the drawing. I can summarize the issue that I want to emphasize as follows. The point on which my model is based is that the main raft, which is strong and spread over a wider area, does not have any function and bearing capacity of the concrete layer underneath without being deformed. If it were, wouldn't we need to do something like this under the side columns as I mentioned above? I know that many of our friends are having trouble with this. I am facing such a problem right now. Although our project, which was modeled as I stated in the same municipality before, has passed, it is currently in the waiting phase. There is a phrase I use all the time: Not everything programs do is right, and everything they can't do is not wrong. Since some control mechanisms want to see everything ONE-TO-ONE in computer output reports and drawings, some mutual communication problems are encountered. Moreover, there are many programs that have been accepted and approved in the market, and the acceptance, modeling and even drawings of each program are different. For example, how to act when the project is brought with the SAP program, which is accepted as a reference. Such problems are generally encountered in small municipalities. Because big municipalities are already dealing with huge projects, such issues are not even ordinary. If that were the case, how would those beautiful projects we watch with admiration come to life? I look forward to your contribution to the subject. Especially the answers given by ideYAPI are even more important in terms of hearing by the relevant persons and all users. (since it is considered official?!) I wish all my friends good work.
