Elevator floor level fault
hewaye
I have a tower with a height of 340 cm from the last floor. I have defined a floor to carry the elevator at 120 cm from the last floor, but when the geometry control is done, it gives an incorrect floor level error. I tried many methods but the solution is inconclusive... can you help me with this issue, good work everyone
Mr. hewaye MY SUGGESTION: IF YOUR FLOOR IS SUCH; APPENDIX: MOLD PLAN As in the attached formwork plan, define the slab, the slab edge (by leaving a distance from the beam) and then change the elevation of the slab. Incorrect floor level error is corrected. Take it easy Unver ÖZCAN
"unver":nw18denz" said:
Sn hewaye MY SUGGESTION: IF YOUR FLOOR IS SUCH: APPENDIX: MOLD PLAN As in the attached formwork plan, define the slab as the slab edge (by keeping a distance from the beam) and then change the elevation of the slab. Incorrect floor level error is corrected Take it easy Ünver ÖZCAN
Thank you for your answer, when you closed the beam layers and made it from the zero, that is, the end points of the curtain, it didn't occur to me to keep the distance, thank you again for your suggestion. Regards...
