Elevator engine room flooring
201968
As you can see in the attached photo, I defined the elevator machine room floor with the floor edge at the top level and gave it a minus level. When I define beams and slabs for the top floor, I get errors in the geometry check. 1- Is my action correct? 2- What is your suggestion on this subject?
Re: ELEVATOR MACHINE ROOM FLOOR
"201968":q0q1ns9j" said:
As you can see in the attached photo, I defined the elevator machine room floor at the top level with the floor edge and gave a minus level. Beam and floor for the top floor 1- Is the operation I have done correct? 2- What is your suggestion about this?
Hello -If you have defined the slab boundaries you have given negative level with the slab edge and defined beams for the slab at zero level, you can use the "Beam slab edge" in the Geometry control. -"Incorrect floor level" warning is caused by the inconsistency of the floor level and the elevation(s) of the elements to which the floor is connected. Edit the floor level in the floor settings and define the floor at the lower level first and then the floor at the upper level. In this case, the incorrect floor level warning Note: -Create a rigid diaphragm in the Static tab from the properties of the slab you defined by giving negative elevation. It would be appropriate to tick the option. Good work
