Element Names not appearing
M.Alper Tunga
Hello, When I open a project that I have worked with Idemimari 8.5 with ideçelik 8.5, when I want to get the foundation plan, the names of the foundation beams do not appear in the drawing. I did research but couldn't find any results. I would be glad if you help.
Hello, If you use the "Make compatible with static" command in the Modify menu, you can make the ideCAD Architectural project visual settings suitable for static format.
This fixed the problem, thank you. Previously I was only using static. Recently, I started to work on architecture. Thank you for your help.
