"oya":2xjz1p3r" said:hello, would there be any problems in the analysis if we define similar elements, especially elements such as columns and curtains, by cloning them...
Hello, by cloning elements such as columns, curtain beams, taking symmetry, rotating etc. You can define it. No problem. You should be careful if you clone a beam on another beam, the beams will not split. Beam at beam intersections. The beams should split each other to form a node/connection point at that point. Good work"oya":1e41ffbn" said:hi, would there be any problem in the analysis if we define similar elements by cloning especially elements such as columns and curtains...
