Editing axes and columns after import
ademkocakaplan
hello, I left only axes and columns in autocad and imported the file into the ide. I started building the axles and columns. However, I could not transform some of the columns (I think it was because it was drawn in pieces in architecture). Instead of these columns, I created a column using the object tab. but I can't delete the lines at the bottom that I imported. why could it be.? Another issue is that the axes I created after importing are not aligned within the axis boundary. long or short. Can I change the axle line lengths? Thanks in advance.
Re: EDIT AXLES AND COLUMNS AFTER IMPORTING Hello, -The reason why some columns do not turn into columns may be because the lines do not form a closed area. -If you cannot select and delete the lines under the column, the layer of the related object may be locked. -You can change the axle lengths by entering values in the left or right delta columns from the axle properties. Good work
Thanks for the info, I deleted the column objects. but I can't make the arrangement related to the axles. I would appreciate if you could help me with the drawing.
"ademkocakaplan":6n319gbn" said:
thanks for the information you gave, I deleted the column objects, but I can't edit with the axis. I would appreciate if you could help me with the drawing attached. Good work
