Eaves production in hollow block building.
semih5252
first of all good work. I want to make 50 cm eaves in my project, which has a completely hollow floor slab. When I define it as the normal slab edge and enter, I can give a depth of 10 cm due to my horizontal beams.. How else can I manufacture eaves..
Hello, Deflection and thickness problem is not seen. 10cm slab can be made as flooring. Or it can be modeled like 32 cm rib flooring.
Thank you very much for your interest, Mr. Yasin. The main reason for asking this question is this; The eave, which has a depth of 10 cm, can be a problem for the master in on-site production, so I wanted to ask how else I can do it, but as you said, I think it would be more logical to enlarge the dimensions with an extra 50 cm and make it that way... again, thank you for your attention.. if I have a problem, I'm here. I will write to you now. :)
