Earthquake regulation 7.11.3 problem in my project
lozhan
Hello, In the attached project, I could not solve the problem consisting of earthquake regulation 7.11.3 checks on d105 and d106 floors on the ground and 1st floor. I would be glad if you help. Good luck with.
Unver, First of all, thank you for your interest. But I don't think this will solve the problem. It is seen that there are some errors at the top (red arrows) in the report you sent. If you look at the pfyd column in the pull reports in the report, you will see that these errors exist. I also think that it is not correct to define it as ribs in terms of continuous drawing of toothed beams.
Hello Mr. Lütfullah, If you remove the reinforcement constants of the floors on all floors and repeat the analysis, the condition of 7.11.3 will be met in all floors.
Thank you, Mr. Hakan. I found a solution for it to be useful. I deleted the reinforced concrete calculation axles of the problematic floors and created them again. Then I changed the way it works to bottom flat and analyzed it. The problem is over.
Hello Mr. Hakan, In this project, d5 and d9 floors are not visible on the cassette reinforced concrete table on all floors. Therefore, detailed drawings cannot be obtained. I would be glad if you are interested in this matter. Good work.
