Earthquake performance analysis reinforcement assignment
leyla12
Hello. I will do an earthquake performance analysis of an existing building. I have to enter the reinforcements manually, for example, I will enter the beams, but there are a total of 100 beams. Do I have to manually enter reinforcement for each beam, for example, there are beams with the same reinforcement, is there a shortcut for this, for example, in sta4cad, we could only select the part of the beams or columns that you want to copy the reinforcements layer by layer and put the same on the upper floors, but I could not see it in idecad.
"leyla12":35sjk4ep" said:
hello. I will do an earthquake performance analysis of an existing structure. I need to enter the reinforcements manually, for example, I will enter the beams, but there are a total of 100 beams. Do I need to manually enter the reinforcement for each beam, for example the same reinforcement For example, in sta4cad, we could only select the desired part of the beams or columns that you want to copy the reinforcements, and put the same on the upper floors, but I couldn't see it in idecad.
Hello, "shift" and "ctrl" in Reinforced Concrete design dialogs You can select more than one row using the keys and thus change the sizes, reinforcements and/or reinforcement fixing states of the selected elements at once.
Good work
