eissenhover
I cannot use the Merabalar.earthquake isolator command. Right click on any column and say define earthquake monitor, select an isolator from the screen that opens, determine its position and say ok, then the bottom command line writes column edge or column select. When you select the same column, the isolator selection screen opens again. I couldn't do a tour can you help me
