earthquake force
yunussacikk
hello, when the formula F1 =Vt x (w1 x h1)/((total)Wixhi) is applied for floors, I find different results for the 2nd floor F2 =65.44*(1473.75/2947.5)=32.22. The value in the table is It turns out 28.38.
Hello. The calculation you made is the calculation used to determine the equivalent earthquake load. However, the Fx and Fy values that appear in the Floor General Information report are the floor forces found from the dynamic analysis and used in the horizontal calculation. Writing the definition given here for Fi(x) and Fi(y) as Equivalent, which rightly misleads you. We have included this situation in our notes. The Equivalent Fx Fy values given in the example Dynamic analysis report given below are calculated as given in the 2007 regulation 2.7.2 based on the Equivalent base shear force. If you add your project file here or send it to the technical service, we will show the verification for this project. Fbk = Ao I wbk / 1.5 is applied on the rigid basement floor. Equivalent earthquake load calculation in TDY in 2007 is as follows:
