Hello there; As of v10.14 some updates have been made to the tiles. Such changes may occur as a result of updates. Double reinforcement (EA) warning in slabs may be due to analysis according to "Consider in-plane forces in slab design" option in Semi-rigid diaphragm method in Analysis Settings. When this option is checked, in-plane stresses caused by earthquake effects are also used in flooring reinforcement design. This sign can be removed and a reinforcement selection can be made depending on the slab stress checks report in TBDY 7.11.3. At the same time, if you mark the floors with flat reinforcement at the bottom and top, a more suitable solution may emerge. Best regards...
