DWG Import Problem?
armedesign
Hello, I'm importing the existing architectural dwg file to idecad, but the grids disappear on the left-hand workplane. Although I activate the grids from the general settings, they do not appear on the work plane, which causes trouble when working. So how do I fix this problem? Thanks in advance for your help
hello... it is necessary to reduce 1/100 (cm) while importing. I also need to move (0,0) to the origin. I had the same problem...even if you check your dimensions after importing, you can notice it. Of course, if the same situation is the case... if it's like I said, after importing, selecting and deleting all the elements, and making full screen scale, the grid appears... I hope the problem and solution are the same, I could help you... take it easy...
By the way, let me tell you something more. Let it be both a comment and a question to the admin... :) But. When I import 70 rafts to the 6-floor building, it does not provide it, when I enter it manually. I asked experienced ide users if I had a problem or if it was really there, they all recommend me to enter it by hand. But it is both easy and convenient to enter by importing..
Send us both projects that you see such a serious difference between, and we'll examine them.
