Dressing facade static
actombo
hello, is it possible to make a static calculation of the curtain wall in idecad? Do you have a sample project? I have received such a request, I have no idea, frankly, I would be glad if you could help. good work
Hello there;
There are different types of curtain walls. If there is an aluminum curtain wall in the type you will use, you can obtain analysis results, internal force diagrams and drawings, but the design results and report in accordance with the regulations are not available for aluminum at the moment. The same applies if you use light steel elements. You can obtain analysis, design, drawings and reports of curtain walls designed using structural steel and tension elements. The file linked above will give you an idea. You need to decide what kind of design you want to make about the curtain wall. Good work.
