drawings
fuatturan
take it easy everyone. I get a drawing after analyzing, but it shows my drawings in 5-6 sheets. I want to put them on a single sheet. What should I do. I would appreciate your help. Thank you..
"fuatturan":3j16qvp0" said:
help everyone. After analyzing, I get drawings, but it shows my drawings in 5-6 sheets. I want to put them on a single sheet, what should I do. I would appreciate your help. Thank you..
In the Drawing Properties dialog, go to the Layout tab. You can get more than one sheet in one opening by increasing the paper width. For A1 89cm x 59cm paper size, you can try by entering 89cm x 5 = 445 cm width to get about 5 sheets at once. You can change the paper width according to the drawings fit on the sheet. You can create a drawing again.
