Drawing Wall Details According to Earthquake Regulation 2018
ismail2982
I have some problems with the curtain. *Can we create the curtain drawings in Figure 7.11? In the new program, stirrups are drawn through the body reinforcements. *Will there be a curved curtain definition? I defined the 12 panel objects surrounding the staircase as a group. However, the drawings are mixed. * On the curtains defined as a group, the warning "curtain length cannot be less than 6 times the curtain thickness" is given in the geometry control. Is this normal? Ide file is attached.
Re: Drawing Wall Details According to Earthquake Code 2018 Hello, two types of wall drawings in TBDY 2018 are optionally added to 10 versions. You can get the curtain drawings in the layout in TDY 2007, as in Type 2. Type 2 where the shear horizontal reinforcements are kept inside, in the type 3 where the horizontal shear reinforcements continue on the body from the outside in the cap area. Arrangements for bow and broken curtains have been added. Drawings and quantities can be taken without any problems. The parameter, which was valid only for beams in previous versions, has been adjusted to work on curtains as well. In the geometry control, the status of being in the group is not taken into account when checking the curtain dimensions. I take it in our notes as a request. Since this control is not printed in the report, you can ignore it.
