Drawing Texts
yeni
Brothers, can you tell me about these 2 photos? i provide a solution 2-basic apl. : My brothers, I created a raft foundation here, when I asked for a drawing, I understood the reinforcements given in the x and y direction, but short distance and top and bottom reinforcement is thrown around the curtain and some column edges, can you explain it to me in advance, thanks in advance
Re: help !!!!!
"new":1bnibnvg" said:
1-beam expansion: here it comes out properly without interfering with the drawing features, but I wanted to enlarge it a bit because the texts and expansions are too small When you mess with the drawing features, it looks like the picture. How can I solve it
In the beam expansion settings, the default reinforcement length text is 4.8 cm. The equivalent of this value on 1/20 scale is 2.4 mm and it is usually sufficient for beam expansions. If you want to see the font sizes larger, you can edit using the 2-dimensional possibilities after taking the beam expansion. (Quick move, move etc commands)
2-basic apl. : my brothers, I created a raft foundation here, when I asked for a drawing, I understood the reinforcements given in the x and y direction, but there is short-range and top-to-bottom reinforcement around the wall and some column edges, can you explain this to me
The reinforcements you mentioned are thrown to meet the bending moments in the relevant coordinates. are additional equipment. Information of additional reinforcements can be viewed from the Reinforced Concrete / Raft Flooring / Additional Reinforcements Tab.
Re: help !!!!! teacher, in short, I will fix this manually, if so, let's say I do a 10-fold study, I won't have to deal with this correction, is there an easy way?
Re: help !!!!!
"new":1oi7w3ba" said:
sir, in short, I will fix this manually, if so, let's say if I do a 10-fold study, will I not have to deal with this correction? There is no easy way. mu ?
If you don't enlarge the font size more than necessary, you won't have to deal with editing too much.
Re: help !!!!! teacher, when printed, the texts are very small, they are almost not readable, it is necessary to look very closely and carefully... in short, if you do not want to edit, the drawing features will not be interfered with and it will remain at 1/20 on the scale. ?
Re: help !!!!!
"new":pk44p0di" said:
my teacher, when you print out, the texts are very small, almost not readable. it will not be confused at all and will remain as 1/20 on the scale ?
Hello, The font sizes in the program are 1/20 for the expansions, the pattern and application plans have been determined according to the 1/50 standard scales, by testing them on the printer. He has done and had countless projects drawn by the greats of this font. You have both enlarged the texts a lot and had additional reinforcements printed on all floors. Enlarging the text means risking mixing in tight spaces. Based on the sample pictures you have added, it will be possible to write the texts of this size in the same format, even if you try to write them by hand. You will have a hard time finding a place.
Re: help !!!!! First of all, I want to say something about drawing: You probably played around with the drawing settings as other friends said. If you don't make any changes, there is no problem. The settings in the attached picture are generally suitable for this. Also in the second image is an explanation of how a drawing will look on paper. In the lower right corner of the screen are the scale factor and face ratio. When you click on this scale factor, enter what scale you want to draw on the paper. Then enter your screen size. Your scale and the text 100% will appear in the lower corner of the screen. You can detect how your drawing will look on the paper and the font sizes by scrolling without zooming. If you wish, let's take a look at the add your project settings. Take it easy, good work. Note: From what I can see from your drawing, your beam has a large amount of body reinforcement and additions. Your beam in question is being overstressed. This dense equipment actually means something else to you. I recommend that you consider this.
Re: help !!!!! Sir, I looked at the drawing settings, it was just like the picture you sent, when I was trying to enlarge the texts and dimensions, they got mixed up.....as a result, when I get the beam expansion in this setting, it is readable on paper. It's okay, right? I need to understand that.
Re: help !!!!! remove the support bars on the short beams, instead increase the lower/upper flat bars. so the drawing is more legible and the application is easier. It may be possible to decrease the number of body irons by increasing their diameters. All your problems with font size will be answered automatically in time. At the moment, my idecad-related software settings and pen settings are fixed and the system works smoothly. scaling information settles in you over time. and "similar beam drawing" is selected for floors. that's why the reinforcement letters are intertwined.
