Draw skinny command
bartayd
Isn't the draw crossbar command not used on normal columns and curtains except for polygon columns? For example, 25*30 columns come out without cross-ties. I want to add cross-ties.
Re: draw crossbar command To draw crossties, it is necessary to select two vertical reinforcements in the plan. Columns or curtains are drawn as blocks in the application plan. In that case, in order to draw a cross, it is necessary to break (explode) the column to be drawn in the column application plan.
