Double reinforcement on floors
yunussacikk
hello, I am getting an error on my beamed floors in the basement, I divided them with beams and created small floors, the problem continued. It seems abnormal to me that I have problems with these floorings. Can you examine it?
Hello, In the project, there are floors on the 2nd basement floor whose mesh cannot be formed. - In the geometry control, the message "insufficient slab or faulty slab axis" is given for DB223 slab. The flooring is faulty. Delete it. -The boundaries of the D11 slab are formed incorrectly. (The elevation of the P16 curtain is not compatible with the slab.) -2. Make data entry so that the joint points of the P14-15-16-17-18 curtains in the basement coincide with the column joint points. Good work
Mr. Levent, I delete the tile and recreate it, it still does not save the tile. It didn't seem normal to me that this small tile didn't save (small tile with joists on the right)
"yunussacikk":zj1ycyuy" said:
levent, I delete the slab and re-create it, the slab does not save again. It did not seem normal to me that this small slab did not save (small tile with beams on the right side)
The problem with the slab is due to the mesh not forming correctly. The arrangements mentioned in the previous message If it is done, the nets are formed correctly and there is no problem on the floors.
