Double reinforcement error
iluhi
In the entrance canopy that I have made, it gives a double reinforcement error on the flooring. I couldn't find the double reinforcement tab in the slab.
Re: DOUBLE REINFORCEMENT ERROR Hello, Due to the magnitude of the moment and the lack of size, the slab section is trying to double reinforcement. There is no double reinforcement design on the floor and therefore the program gives you a warning. But; There may also be an error in your tile data. Check the slab outer contour. Check the geometry. If there is no problem with your data, increase the slab thickness and design the section to work with a single reinforcement.
Re: DOUBLE REINFORCEMENT ERROR hello Mr. Hakan. I have the same problem, although the slab is symmetrical on the left, there is nothing on that slab, but there is a double reinforcement error in the d24 on the left. It doesn't appear in geometry control, how can I double reinforcement? or in the concrete slab tab, I can correct the purple text and turn it back to normal and according to what I need to add reinforcement. When it is red, when I add reinforcements, the problem is fixed, but when it is this color, it does not affect what I do. thanks in advance
"clphkn":2aiklco2" said:
hello sir. I have the same problem. Although the slab is symmetrical on the left, there is nothing on that slab, but there is a double reinforcement error on the d24 on the left. It doesn't show up in the geometry control, how can I do double reinforcement? or I can correct the purple text in the concrete slab tab and turn it back to normal, and according to what I need to add reinforcement. When it is red, when I add reinforcement, the problem is fixed, but when it is this color, it does not affect what I do. Thanks in advance
Hello, Data There is a problem in the entry. Check the answer to question 10 in the attached link. If you can't solve the problem, we will help if you add your project.
"clphkn":32ulq4hz" said:
hello sir. I have the same problem, although the slab is symmetrical on the left, there is nothing on that tile, but there is a double reinforcement error on the d24 on the left. it doesn't show up in the geometry control, how can I do double reinforcement? or I can correct the purple text in the reinforced concrete slab tab and turn it into normal and according to what I need to add reinforcement. When it is red, when I add reinforcement, the problem is fixed, but when it is this color, it does not affect what I do. Thanks in advance
Hello Hakan , in addition to the same problem, insufficient reinforcement error occurs. I am correcting these errors and analyzing, this time another slab that did not give an error before, gives a double reinforcement error and / or insufficient reinforcement error. (This has happened many times and now it continues like an endless loop :/ :/ :? ) I just did a tile analysis and tried, there is no error in that sense.
"DEXTER":25mpce2f" said:
Hi Hakan, in addition to the same problem, insufficient reinforcement error occurs. I am correcting these errors and analyzing, this time another slab that did not give an error before gives a double reinforcement error and / or insufficient reinforcement error. The situation has happened many times and now it continues like an endless loop :/ :/ ) I just did a tile analysis and tried it, there is no error in that sense.
If you add your project, we can take a look.
