lilahmiharbi
I have a project with 2 basement floors + 13 floors and an elevator tower on it. When I have my project analyzed with a semi-rigid diaphragm, I get the error that the beam exceeds nmax in the 2nd basement. There is a shear wall with a height of 2m just below the beam where I get the beam nmax error. The reason why the curtain has a height of 2m in that part is that it coincides with the basement ventilation. Again, I get a double reinforcement error on the floors in the basement. When I search your forum, it says that this error is usually caused by incorrect tile boundaries, but when I check the tile, I see that there is no problem with the tile borders. Can you help by reviewing my project? If there are errors in data entry, can you write them too? Thank you for your interest. Best regards; Project file:
Log in or register now.
